Do cannondales use a Mass Air Flow or O2 sensor system?
Old May 22, 2002 | 08:22 PM
Rockey's Avatar
How does the ECU compensate for altitude changes and feedback from the exhaust to determine injector pulse width? Also, what size fuel pump is on it? Can an aftermarket adjustable fuel pressure regulator be installed to tune it a bit? Of course, all this can be done thru software in the ECU's tables but I was wondering if there were alternatives.
Old May 22, 2002 | 09:17 PM
smitty911's Avatar
Rocky,
They have a altitude sensor in the ecu box. They don't have a O2 sensor. They just use the motor sensor, trottle position sensor, altitude with the map as far as I know.
You thinking of running more fuel presure for more power? You will need to take the engine up a couple of notches before you see the bennies there. By that I mean the motor will have to built so that it needs more than the stock set up can provide.
Have you riden one yet? It will surprise you the way it is.
Smitty
Old May 22, 2002 | 09:30 PM
Rockey's Avatar
I defintiely believe it is a fast bike. I have yet to hear anyone complain about the power from a Cannondale. I was wondering if they used any type of feedback to change the injector pulse width. By leaning the mixture out you can achieve higher power. Remember lean is mean. Of course that is true up to a certain point when the combustion temps get too high and cause preignition/ detonation, then bad things happen. Thanks for your input about the altitude sensor, that helps.
Old May 23, 2002 | 01:26 AM
KNOWSALOT's Avatar
The Facility
Yes, You can alter the pulse width. It wakes them up. It's the best single mod you can do to a Cannondale. They are too rich out of the box.
By leaning them, you give it a real kick in the pants. Not only that, but it takes care fo the plug fouling problem which plague some models.
Old May 23, 2002 | 01:20 PM
Nut's Avatar
Nut
I think they do use an O2 sensor. I was looking at the wiring schematic last night and I do remember seeing notation for it.
Old May 23, 2002 | 01:48 PM
WyoDuner's Avatar
I would almost think an 02 sensor is mandatory otherwise the ECU wouldn't know if it is lean or rich??? As far as the altitude sensor (MAP Sensor???) isn't that how the early fuel injected cars did it before moving to MAF sensors?
I would think an altitude sensor wouldn't be able to account for any airflow mods??? Just thinking out loud.
Old May 23, 2002 | 07:31 PM
cannondale27's Avatar
There is no o2 sensor on the cannondale the system is what is called open loop.The computer has as many variables progrmmed in it like alltitude airtemp,rpm,throttlepos,etc.So what happens is the computer takes all these variables into acount and runs the motor at whatever settings were originally programed into the comp.With a 02 sensor it would do the same but it would also compensate for a rich or lean mixture which was caused by variables that werent accounted for in the programing whithin a range that is closed loop.Guess what there is a pis tail in the harness for a 02 I am all for one as long as we can change the fuel ratio sometimes 14.7to1 isnt the fastest.
Jeff Roper
Feb 1, 2022 11:48 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Oct 10, 2015 10:20 AM
Jeff Roper
Sep 21, 2015 02:11 PM
