Part to full throttle stumble?
Old Dec 22, 2002 | 05:36 PM
jigggawatt's Avatar
Default Part to full throttle stumble?
I have a 03 cannibal le. It has about 3 hours on it . It was broke in then the oil and all filters were changed. The dealer said he installed the speed mapping fo me. It will stumble from part to full throttle sometimes. It did not seem to do this with the factory mapping . Any ideas ? I also have a second ? How do you think the glamis mapping will work? I want to keep the stock pipe but I'm looking at buying the software for mapping and is the glamis mapping avail?
Thanks,JIM
Old Dec 22, 2002 | 07:23 PM
Kodiak01's Avatar
I have an 03 Speed with around 3 hours on it and it also stumbles once in awhile when going from part to full throttle.
Old Dec 22, 2002 | 07:40 PM
jigggawatt's Avatar
While going in the whoops it really bites. It wants to throw you over the bars.
Old Dec 23, 2002 | 08:41 AM
dubya1's Avatar
Did they recal the throttle when they installed the new map? This could be your problem. Hope this helps
Old Dec 23, 2002 | 08:45 AM
cannondale27's Avatar
Bring it back to the dealer he should have written all the stock values yours had on a piece of paper or they might still be stored in his computer.Dealer cal stores the last four maps and values.Have him compare them to what is in there now.Also the throttle calibration.The instant response of both getting on the gas and letting off can seem like stumbling especially in the whoops.If it doesnt do it on flat surface it would be you moving the throttle without realizing it.You might want to try the moto map it doesnt have such a hit on top and is easier to mx with.Otherwise you just have to keep it pinned through the whoops.Going from my R to the dale I noticed the same thing it took a while to get used to.
Old Dec 23, 2002 | 08:53 AM
dubya1's Avatar
Hey Cann27,
Does TA have a Blaze on the floor? Or do you know if one is on its way? Thanks
Old Dec 23, 2002 | 10:13 AM
jigggawatt's Avatar
IT's is for sure a stumble. I can have the throttle mid rpm and go to full . it will stumble long enough to feel like you slammed on the front brakes and then hit very hard. I've always ridden the whoops in the middle of my power . I don't want it hitting the rev limiter in the middle of a set. Thanks for all the help it looks like back to the dealer
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
