Adjusting front Ohlins
Old Dec 24, 2002 | 05:46 PM
Kodiak01's Avatar
Default Adjusting front Ohlins
Is there any other way to adjust the front ohlins on my Speed other than using spanner wrenches?
Thanks
Old Dec 24, 2002 | 06:43 PM
armoks's Avatar
This may sound bad but, I just put the front end up on a stump to take most of the pressure off them then grab the spring with one hand and push down, then twist the lower ring with my other hand it's pretty easy that way.
Old Dec 24, 2002 | 08:58 PM
lt250r91's Avatar
Correct, get the front end off the ground however you can. Then use a couple vise grips that lock into place to remove tension off the adjuster and the change the setting by either going to another notch on the 3 position spacers or move the retaining clip up or down as needed.
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
