More bottom end & map ? And dealer ?
Old Jan 23, 2003 | 02:23 AM
jigggawatt's Avatar
Default More bottom end & map ? And dealer ?
I 've got a 03 cannibal. I'm running the Glamis map with stock exhaust . I would like more torque in the lower rpm's. Which would be the best map for this? Which would be the best pipe for this? Can I run the moto map with the stock exhaust ? I've got the maint. software so I can change maps. What gearing is the best ? I can't use 5th very much it falls on it's face, way too tall . I live in sothern Ca. is there a good shop or dealer around Riverside.
Thanks,JIm
Old Jan 23, 2003 | 09:14 AM
dubya1's Avatar
Jiggawatt,
Try that new Speed map. 31300. Download it from CDale and try it. I think it will give you most of what you are looking for. Hope this helps
Old Jan 23, 2003 | 12:27 PM
jigggawatt's Avatar
Thanks for the info. I don't understand which setup is going to pull harder. What is the Blaze map like? Will the speed map pull hard in the lower R's ? Will I hurt anything buy using the moto map with stock exhaust? I weigh 220 lbs and word like to try to get the most bottom end I can . When I put paddles on it ,it really effects the power. The bigger bore bikes I've owned don't seemed to be effected as much. thanks!
Old Jan 23, 2003 | 12:35 PM
dubya1's Avatar
A local guy is doing 3rd gear starts with the new Speed map and getting holeshots. Try this link. We have a couple of traction maps that may work for you. They pull hard while they hook up. I will try some new maps and keep you posted. PS Try Gabes MotoSpeed map. I haven't tried it yet. Let me know.
Maps
Old Jan 23, 2003 | 12:43 PM
jigggawatt's Avatar
Thanks!
Old Jan 23, 2003 | 12:45 PM
jigggawatt's Avatar
One? are these maps safe? I'm I going to hurt anything i should know about?
Old Jan 23, 2003 | 12:48 PM
dubya1's Avatar
It is always advised to do a plug check. I feel though that you will not "blow" or seize the motor. Many of people have loaded these maps with no problems. If anything they are probably a little "rich". Hope this helps
Old Jan 23, 2003 | 03:13 PM
markvette's Avatar
our moto is running a 13/40 gear and josh comes out of the gate in third. the cannibal we had before the moto burned 2 holes in the toaster with the moto map. we are also running 18" rear tires.
ultangler
Nov 30, 2024 01:35 AM
Johnny Mac
Aug 15, 2019 03:13 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
