Land, Trail and Environmental Issues Discuss political and social events effecting where we ride. Do not enter here unless you are willing to disagree with the statements made. What happens in this forum and Sub-Forums stays in these forums.
1987 Suzuki Lt250R Spark Issue
Old Mar 1, 2025 | 12:39 PM
WildBill1987's Avatar
Default 1987 Suzuki Lt250R Spark Issue
I am having issues with starting my ATV. If I get a new spark plug, it will spark on the first try and then nothing. I replaced the coil but it has the same problem. Conducted the magneto coil test in the Clymer manual which checks the pickup coil, power source, and lighting coil; everything checked out. Please help!
Old Mar 8, 2025 | 02:14 AM
Check all the wiring to the CDI, including earth and kill wires. If they all check out, it is probably a faulty CDI, but they usually work or they don't so this would be a bit unusual. If you can, check the pickup and power coils are producing AC volts when engine is spun over, I don't know what an LT250R should be, but pickup is usually 0.4v or more, and power source circa 50v.
Old Apr 12, 2025 | 02:45 PM
Merryman,
Thanks for the advice. I was busy with other issues for a bit but got back around to troubleshooting. I replaced the coil and the magneto but it was doing the same thing with intermittent spark. I disconnected all of the wires from the CDI and reconnected them and it turns out one of them was loose as when I put it all back together it had continuous spark and fired right up.
willard13
Oct 18, 2010 07:59 PM
brian_leeth2000
Jan 8, 2010 11:56 PM
dgratvbikeshop
Apr 2, 2009 06:00 PM
go-hard-or-go-home
Jun 4, 2008 03:50 PM
Cox1231
Jul 8, 2003 12:41 PM
