Galvanizing?
Old Nov 3, 2004 | 03:10 PM
ttaylor's Avatar
Default Galvanizing?
Does galvanizing need to be removed from metal before it is painted? I want the paint job to last a long time I just didn't know if I could put a coat of primer on first then paint and that would work or if i needed to remove the galvanizing first before I put the primer on?
Old Nov 3, 2004 | 11:14 PM
kybabyn's Avatar
not sure on that one all i know is that galvanizing contains lead that is why if you weld on it and breath it in you can get lead poisioning.
Old Nov 3, 2004 | 11:15 PM
kybabyn's Avatar
a thought came to mind. in old paint in the olden days why did they put lead in paint. maybe it helps it stay longer?
Old Nov 3, 2004 | 11:18 PM
WISTECH's Avatar
I believe its zinc not lead . Lead wouldnt be a very good coating. It oxidizes rapidly.
Old Nov 4, 2004 | 11:04 AM
pangborn83's Avatar
I am not sure if galvanizing needs to be removed but reguardless you need to do a good sanding on it to get the metal preped for any type of primer or paint, then I'd shoot some etch prime (or epoxy primer) then a little primer filler, block that and then spray color that will give you the best results.
Old Nov 4, 2004 | 11:35 AM
ttaylor's Avatar
Thanks, I guess it is off to sanding then. I was hoping to be able to leave the galvanizing on since it would be a good rust inhibitor.
Old Nov 4, 2004 | 11:55 AM
Heathen's Avatar
Galvanizing does not need to be removed. There are vehicles that have galvanized sheet metal.
Old Nov 4, 2004 | 11:59 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I agree with Heathen on this. All the steel rain gutters that I have seen are galvanized, then painted to match the house.
Old Nov 4, 2004 | 12:25 PM
ttaylor's Avatar
Is there a special application for the painting process? or will a regular primer do?
Old Nov 4, 2004 | 12:39 PM
KTM Patrol
Former Chinese POW!
The cheapest way I know of to etch gal. steel is with white vinegar from your local market. Scrub the metal with scotch brite and vinegar, rinse with water, then dry with a cloth. Do not let air dry. Next you should use a zinc chromate primer, now you can paint with any paint you want.
