What's the best plastic cleaner??
Old 10-18-1999, 11:45 PM
Wils400EX's Avatar
I just bought a '99 400EX and I want to keep the plastic shining and looking new as long as possible. What is the best thing to use?
Thanks
Wils400EX
Old 10-19-1999, 12:46 AM
EXtreme's Avatar
Most everybody is using stp son of a gun for weekly maintenence, but someone else posted using several thin coats of Mop n Glo for the nasty areas...it works!
Steve Small, 00' 400ex, 00' 325 Trail Boss for the Mrs.
Old 10-22-1999, 12:08 AM
Hank's Avatar
I have the same question and concern. I recently bought two used ATVs. A 99 Honda Recon and a 98 Kawasaki 220. I believe in riding them, so the plastic is getting scratched and rubbed spots. I tried auto wax but it didnt seem to do much. I had one guy in a chat room tell me to use Mayonaise. LOL
Has anyone heard of that? HELP!
Old 10-22-1999, 03:28 PM
mudfly's Avatar
I have found washing it good with Dawn and water first, letting it dry and then applying a coat of silicone spray lubricant works VERY well. I have found Pyroil brand to work best. Mud cleans off very easy. (That is unless you have been riding in the mud for the entire day and have completely wiped out the coating of silicone.
Chad Ruehl
98 300EX (slightly modified)
Old 10-23-1999, 06:52 PM
kclayd's Avatar
You can use different ones. I first tried Tire Care. That's the stuff used to make car tires look new again. Now, I just use that on my black plastic, tires, and internal stuff. It can clean and shine up your engine and hoses. I have used Armor-All with success on the colored plastic and seat, as well as STP Son of a Gun. They both work well. I suggest spraying them from a distance to get maximum effect, let the spray soak for awhile, and then use a soft cloth to clean away the residue. I don't like 10W40 silicone spray, because it leaves a greasy film, which is hard to remove, and it just doesn't get the same shine as the others I mentioned.
Good luck.
[This message has been edited by kclayd (edited 10-23-1999).]
[This message has been edited by kclayd (edited 10-24-1999).]
Old 10-25-1999, 12:25 AM
Blaster668's Avatar
Use armor all or similar product like STP son-of-a-gun. But when you put it on for the first couple of times spray it on real heavy and let it soak in overnight. I have found that WD40 gives a real good shine and makes it easier to clean mud and dirt off but I have heard that it is bad for plastic so I don't use it anymore.
Garrett Lowman; CT240 Blaster, YZ490
Old 10-25-1999, 01:47 AM
THEXOTIC1's Avatar
Clean the plastics real good. Let them dry. then apply a couple of coats of Mop And Glo. It makes the plastics shin like new again. And if you have dark colored plastics it will even hide the scratches.
Alex
Old 10-25-1999, 09:07 PM
corncob2's Avatar
Tried the mop-glo looked like hell.What have I done wrong was real streaked.Have red 500sp.Someone mentioned spraying the seat,how do you stay on after that?Only made that mistake once couldn't stay on seat,was glad when it wore off.
Later COB
Old 10-26-1999, 01:38 AM
EXtreme's Avatar
cob, lots of thin coats that dry 15 minutes apart. Try to acheive the "wet look". After its good and dry, give it a good dose of son of a gun or armor all and watch it shine! Granted, it ain't perfect, but it's better than road rash red.
Old 10-26-1999, 09:43 AM
Zombee's Avatar
Definitly use STP Son of a Gun. Make sure it is clean then mist the entire bike in it. It will keep the bike protected and looking new for years. Not to mention it will clean up much easier the next wash.
Quick Reply: What's the best plastic cleaner??
