Trailers for quads
Old Oct 9, 2006 | 03:23 PM
  #21
MikeMac707's Avatar
Default Trailers for quads
Originally posted by: MadInventor
5 flat tires. ouch!
My son drove something through the sidewall of one of my wifes tires at about 10 miles on the machine, but haven't had any problems since. Tore a lot of chunks out of the edge of the aluminun rims though. Do any of you guys use tire sealer in your tires? I seem to be developing slow leaks on a few tires.
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 22, 2009 | 10:39 AM
  #22
plumbstraight's Avatar
Really interested in how you plan to pull two trailers side by side. Backing up is going to be quite a challenge and going around a corner they will be eating at each other.
I built a utility trailer that is a bit different. It is the width of my Dakota so I don't have to worry if the wife is pulling it that she will hit something with the axles. It has the regular sides the hieght of a gascan. Then it has sides that fold down from the edges to the middle to make a flatbed. You can put all the campgear, fuel, etc in the utility, close the cover, and put a couple of quads right up on top. The folding sides also can be tipped in a bit and a tarp tossed over for a shelter if someone wanted to sleep in it. Also the sides just pull back to slip off the hinges. The right side can be slipped back on and used as a table full length and half the with of the trailer out to the side. It is also a tilt deck so you can load without ramps if just using the utility part of the trailer.
Reactant
Mar 30, 2022 02:08 AM
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
RickyMac
Mar 5, 2016 07:27 AM
