Kill switch question
Old Jul 13, 2003 | 07:32 PM
DIGGEM's Avatar
Default Kill switch question
The ASDA requires me to have a tether style kill switch to compete, I installed it on my Quad that has a GS 1000 engine in it, I thought that I would just hook it between the key and the coils and when it was pulled it would disconnect power and kill the engine, But the switch is designed to ground out the coils when pulled ( backwards of what I am trying to use it for ) How do I wire it to ground the coils.
Click on sig for pics
Old Jul 16, 2003 | 12:01 AM
QUE's Avatar
QUE
I hooked mine to the kick stand switch. Most Zuk's have a kick stand switch. You wire it to day and it makes the motor think the kickstand is down. Or just put a screw in the engine kill switch on the bars. When you pull up it will kill the motor. Hope that helps
Cheers
Old Jul 16, 2003 | 12:11 AM
DIGGEM's Avatar
Quad's dont have kickstands
Old Jul 16, 2003 | 12:22 AM
QUE's Avatar
QUE
You said it has a GS motor most motorcycle motors do have kickstand switches
Old Jul 16, 2003 | 12:25 AM
DIGGEM's Avatar
Nope, It's stripped down to the bare bones, I need to wire it to the coils somehow.
Old Jul 16, 2003 | 12:30 AM
QUE's Avatar
QUE
Use a 30 amp relay and reverse the polarity to the kill switch using the kill switch as the kill switch as the ground. The tether is pulled killing the ground and cutting the 12 volt source to the ign. killing the motor. I should have read more into your post.
Cheers
Old Jul 16, 2003 | 12:33 AM
UBETRUN's Avatar
You need to ground the + terminal of the coil(s). If you have more than one coil, you need to run a parallel wire to both + terminals from one side of the tether switch. When the tether is pulled, the switch closes and connects ground to the + terminal of the coil so it can't generate any spark.
Old Jul 16, 2003 | 09:08 PM
DIGGEM's Avatar
Is it going to interfear with the coils if they are both wired together?
Old Jul 17, 2003 | 10:54 PM
QUE's Avatar
QUE
Give me a fax# So I can send you a wiring diagram so you can hook it up
Old Jul 18, 2003 | 08:41 PM
DIGGEM's Avatar
I sent you a PM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
sublime250
Jul 11, 2015 11:52 AM
