Alba or WB
Alba or WB
I have the wb e series pipe on my warrior and with a filter and box vents i am amazed at the power. It runs ok without jetting the carb but i have to do so because at full throttle it is running slightly lean, all i have to do is move up the clip on the main jet needle and the power should be better. if i were u i would definely go with the wb, and if u order it from www.rockymountainatv.com they should give u a free wb filter with it.
