Which frame to use with a 1000cc triple
  #21
Old 11-12-2003, 03:28 PM
DaBeechMan's Avatar
Default Which frame to use with a 1000cc triple
If you dyno a cvt motor at the crank then your not dynoing the cvt now are you? If you cant dyno a quad/sled with a cvt then tell me why they make track dyno's? I guess all these guys are just wasting their time...
  #22
Old 11-12-2003, 04:03 PM
SHOTGUN's Avatar
I didn't say you couldn't dyno a cvt snowmobile or quad, I said you can't compare the dyno numbers for a cvt and a standard and the right way is to dyno off the crank.
  #23
Old 11-17-2003, 01:01 AM
kennyboi's Avatar
I would get a warrior frame it my be heavy but with all that power you are going to need some weight, and theres plunty of engine rooma 250r frame i think would be to small 4 that big engine..good luck
  #24
Old 11-23-2003, 10:47 PM
Quadzilla1000's Avatar
If you do the street bike motor or the sled motor go with a Banshee Frame there are more aftermarket parts for the banshee frame than a quadzilla i have a quadzilla with a R1 motor and its very fast BUT there are alot of things i would do diffrent if i could star over, Just take my advice and use a banshee frame!
  #25
Old 11-24-2003, 12:00 PM
Motoxracer34's Avatar
thanks quadzilla, finally someone who has done what I am going to attempt
  #26
Old 11-28-2003, 09:15 AM
getusummm's Avatar
I am just curious. Has anyone ever tried to mate a snowmobile engine to a harley type transmission? Is it feasible, aside from tranny cost? Just something I have been pondering. I cant seem to find an online parts diagram, so I am not sure what it would take, but it seem that this would eliminate alot of the lost hp. Just a thought, so no bashing please, lol.
  #27
Old 11-28-2003, 06:30 PM
SuzukiZ250Kid's Avatar
You could easily mod that Arctic Cat engine to over 200hp. One of my friends modified his Arctic Cat Thundercat to eventually get almost 300hp (284 I think) and a top speed of 225mph (you can do a lot with an unlimited budget). It only took a few hundred dollars in mods to get up to 220hp at the track. After that is when he got totally speed hungry and spent close to $3000 on mods.
  #28
Old 11-29-2003, 04:06 PM
mxquadracer's Avatar
beech is that banshee really a 580? if so can I get a dyno copy of it?
  #29
Old 11-30-2003, 04:23 PM
jed250's Avatar
Originally posted by: SHOTGUN
A good 1000cc open mod sled motor will put out about 260 HP, and run 5.1 to 5.3 in 660 feet, at speeds in excess of 130 mph.....that's not fast?
The right way to dyno a CVT is at the crank. CVT are always trying to shift up. you can't stay in a direct drive like on a standard, that is the reason for the Hp lost.
Unless your going full pin.
  #30
Old 12-01-2003, 01:06 PM
DaBeechMan's Avatar
never been dynoed. Sorry.
Dennis packard did the harley tranny on a banshee crank case. the project never completed so im sure it had its problems
Quick Reply: Which frame to use with a 1000cc triple
