Z440 needs help(big bore kit)
Old Jan 19, 2004 | 02:27 AM
KFXCarnage's Avatar
Default Z440 needs help(big bore kit)
On the 440 kit do they bore your stock cylinder or send you a new cylinder?Also if bored does it cause it to over heat more and more prone to cylinder dammage since the walls are thiner?
Old Jan 19, 2004 | 08:14 AM
z838mx's Avatar
You can do it one of 2 ways either you can bore the cylender and have it re-nikisiled or you can have a sleeve intalled. Its your choice for racing I resleeved mine so if I blow it up my down time is not as long. I can have parts quicker and the machining is only a day for that here but to re nikisil the sleeve takes 1-3 weeks depending on who does it I have a race about every week so Id miss up to 3 races doing it that way but its the better way to do it. 440 is the max bore you can do on the cylender before re-sleve. sleving will make it run hotter over heat I doubt it. But anything can overheat in the right condetion.
Old Jan 19, 2004 | 06:02 PM
BlueZ440's Avatar
I want to say thanks to all yall that reply. Bulldogz400 you are right about the Hot Cams. It does sound like a fast ticking noise. As for jetting I went up to 160main jet. finally my friend that installed my big bore kit took my Z down to the shop and did some work to it. We clean out the carb,tank and put new gas in it. Also we added a washer to the needle so that more fuel goes in.(Stage 2 needle on it's way). The last thing we did was change the pilot jet to 25.(stock is 22.5) So I took my Z out this weekend and it ran perfect no issues at all beside the fast ticking noise but that's normal according to my friend and Bulldogz400.
Z440
Full Yoshi pipe
Wiseco 12.5:1 piston
Hotcams Intake and Exhaust
Uni Filter
Dial-a-jet
maier plastic(Blue)
K&K Graphics
Holeshots
Old Sep 27, 2005 | 06:26 PM
zzz1's Avatar
Yeah.
I ave a z400 pipe jetted filter and was wunderin were to go next i want in region of 40hp[img]i/expressions/face-icon-small-confused.gif[/img]
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
