Carb Question Help!
Old Aug 17, 2000 | 07:45 PM
BurleyOne's Avatar
I am helping my neighbor work on his 95 Bayou 400 and we took the carb off and cleaned it really good changed the vaccum valve on it and its running fine but there is fuel coming out of the drain on the bottom of the carb and im not sure how to stop it
thanks for any answers
Old Aug 17, 2000 | 07:49 PM
FOREMANes's Avatar
the overflow...??? is that where the gas is coming out??? if so it could be the floats are stuck or set wrong......
Just a thought
Old Aug 17, 2000 | 09:14 PM
WyoRider's Avatar
If it is the drain and not the overflow it should be just a screw that you tighten down to stop it from draining. Maybe an o-ring or washer fell off of that screw?
Old Aug 17, 2000 | 10:47 PM
Tree Farmer's Avatar
Sounds like the float valve is not seating properly; maybe you loosened a bit of trash that's preventing the float valve from seating, or maybe you bent the float tang where it can't close the valve.
I'd check: 1) Float valve and seat for squeaky-cleanness; and 2) Float height.
(I'm assuming you tightened the dump tube valve screw.)
There's an article on Keihin CV carburetor maintenance in "Tech Tips," accessible from the ATV Connection home page, possibly containing some information useful to you. Also, you can look at an exploded parts diagram of your carburetor in the parts catalog section of www.buykawasaki.com. Good luck!
Tree Farmer
Old Aug 18, 2000 | 03:44 PM
WyoRider's Avatar
If it was the overflow wouldn't the gas becoming out at the tob of the bowl; he said it was coming out of the bottom of the carb. Although, it is about 1 billion times more likely that the leaking gas is float related as opposed to the drain screw.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
