Fatty Pipe Problem
Old Sep 4, 2000 | 12:40 AM
Kybol's Avatar
I got a FMF Fatty pipe ands it syas to file 10 thousanths off of the ring, How do I do this or does it matter if I do it or not?
Old Sep 4, 2000 | 12:56 AM
rsss396's Avatar
clamp it in a vice with the open end on top and open enough to slide a small fine cutting file between. remove only enough so the ring will fit inside the pipe end without forcing. You could also grind down with a die grinder but be careful because you won't be removing that much. make sure you file the end square so the ends of the rings but up nicely.
Old Sep 4, 2000 | 01:07 AM
Kybol's Avatar
Thanks I'll try that and see if it works.
Old Sep 7, 2000 | 03:20 PM
Adams44's Avatar
Hey Kybol; Based on the last posting, I only had to file about .005 to .008" off before it fit nicely. This also eliminated the rubbing problem on the right front a arm mount.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
traumajunkie
Jul 23, 2015 02:10 AM
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 12, 2015 07:42 PM
