White Brothers Repacking
Old Nov 17, 2004 | 09:56 PM
hotrod0688's Avatar
Default White Brothers Repacking
How often do you need to repack a WB E-Series and how do you repack it?
Old Nov 19, 2004 | 03:27 AM
pendejo's Avatar
When your bike gets louder than usual, or the packing starts blowing out the silencer. It's not hard, you either have to remove the retaining bolts and pull the muffler apart or drill out the rivets and pull it apart. I would recommend that you use bolts instead of rivets when rebuilding silencer. Also, don't buy that expensive repacing laterial they sell, pick up a piece of insulation from Home Depot, it's pink and I think called "R11", I used that several times in my R, and it was still quieter than my friends LT with the "true" packing.
Old Nov 27, 2004 | 12:20 AM
jesbuilt's Avatar
I can see the use of the R11, But, How long does it last? So far I have only had to pack mine on the sportsman two or three times a year.
Thanks
Jes[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 19, 2005 | 05:30 PM
Dougget's Avatar
When you drill out the rivets, do you need to remove them from both ends of the can, or just the end by the exhaust tip?
I've removed the tip and disks from my E-Series then drilled out the rivets, but the core will not budge.
HELP!!!
Thanks,
Doug
Old Jul 19, 2005 | 08:18 PM
hotrod0688's Avatar
I drilled out both ends of mine to repack it, that way the core will completley come out. Also a little WD-40 helps in case it's rusted just a little bit.
Old Jul 20, 2005 | 12:06 AM
Dougget's Avatar
OK, I drilled out both ends and got the core out. First time doing this, so I was surprised at how tightly it was packed. I was going to repack with household wall insulation, but since it's such a pain to open up, I think I'll spring for some universal packing material from a cycle shop.
There is one other mod I would like to do... Just wondering if I could put an internal baffel inside the core? Right now, the exhaust flows straight through the core. The perforated metal lets the fiberglass absorb some of the thump, and the disks and spark arestor cause some backpressure. It's still kinda loud. If I could put something in the core to cause some turbulance, that may help the high/low pressure pulses to mix and quite it down a little.
So what do you think? I thought about using some stainless washers. Bend them to form a small tab, then rivet them to the inside of the core. Maybe 2 or 3 inside the core... I don't know, maybe I'll sleep on it.
Once I figure something out, I'll post some pics and give a follow-up report.
Thanks,
Doug
Old Jul 20, 2005 | 12:45 AM
hotrod0688's Avatar
That might work but I'm not really sure. I have really never messed with that but mine is straight through and then I bought the turn down end cap just to make it louder. But whatever works.
Old Jul 26, 2005 | 10:40 PM
Dougget's Avatar
I know, it's a bike... But a muffler's a muffler, right?
I just finished repacking my E-Series pipe. Here's a write up...
E-Series Rebuild
Doug
Old Jul 29, 2005 | 09:01 PM
SPORTSMAN70003's Avatar
E-Series Rebuild
Doug
Nice job on the write up.
Pehter
Oct 3, 2024 11:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
