HELP MY YFZ 450 is in alot of TROUBLE
I got the graphics from DUNCAN RACING(look them up on the web).Sounds like you may have a lean condition.Generally the motor getting flat like that is a sign of a lean condition.5th gear is not going to pull like 2nd and 3rd.Is the quad still gaining speed?.......
Originally posted by: TBONE31
yeah only in fifth....it sounds like UHHHHHHHHHHHHHHHHHH. Usaually the YFZ accelarates mine doesnt
Thanks............Yeah i went to the website and im ordering them.....It shifts really quick from 1 to second and im accelerating pretty quick. Then 3 to 4 is the same.......still accelerating.......then when i get to fifth i push half throttle and it sounds HORRIABLE.
is it just like a lugging sound? I know when im not revved out in 4th and i go into 5th on my rappy, that the engine just kind of chugs along. 5th gear is so high you wont be pulled as hard as you were in 1-4th gear, 5th gear is pretty tall. check your plug see if its white, you might want to go up a size on your main, where you from? Maybee its cold their like here so it runs a little leaner then normal in cold weather.
#15
If it was rich on top the pipe would not be glowing the excess fuel would cool the pipe sounds lean to me. I am Not familiar with the YFZ but try using a lit bit of choke on the big end if it clears up and speeds up its lean if it gets worse it is rich. My 2 cents
#16
#18
mrtidy
02-03-2016 05:00 PM
