sprocket
Old Mar 29, 2005 | 10:50 PM
fast700rappy's Avatar
Default sprocket
i heard the it is better to go with a smaller sprocket in the rear than going with a larger one in the front is that true
Old Apr 3, 2005 | 12:36 PM
87250xman's Avatar
Default sprocket
Change the front sprocket it makes more of a difference. Small give to more low en and larger give use more top end. For the back sprocket its the opposite.
Old Apr 4, 2005 | 05:01 PM
ZillaRider87's Avatar
Default sprocket
the rear sprocket is to basically fine tune the gearing
Old Apr 6, 2005 | 07:52 PM
2strokegood89's Avatar
Default sprocket
front sprockets are cheaper. since it is a smaller sprocket just 2 teeth change will make a big difference
Old Apr 7, 2005 | 11:50 PM
mucky's Avatar
Default sprocket
as for sprockets it takes 3 teeth in the rear to equal 1 in the front
the rear is for fine tuning how much power or torque you have
1 tooth in the front up will give you top end speed, 1 down will give you torque
I run 13/39 so I have the torque but not as much if I was running a 13/40
I used to want to go as fast as I could get but after crashing at 51mph 1 month ago
I would rather have the torque then the speed
Old Apr 8, 2005 | 12:02 AM
Default sprocket
it isn't cause I wana go fast it is cuse i wana get traction all i do is spin I was told the kit that I had built was going to give me 58-65 hp and I don't know about torque
Old Apr 12, 2005 | 09:17 AM
TBONE31's Avatar
Default sprocket
are you from NY
Old Apr 12, 2005 | 06:04 PM
Default sprocket
nope I am from minnesota
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
