SAVING THE REVERSE?
Ummmm, I wanted to do this too when I had my 300ex, but couldnt really figure out how to make it work. I know that with the start in gear thing, you just put the wires together to make it keep working, as for the reverse, I am not totally sure how it would work. Maybe trace the wires that it uses and then put them together while you still have your other lever and see if it works, if not then it wont work, if so, put on your PEP.
I dont know what clutch lever mods you have made but I have done the same for my wife,s 300 . As follows : removed complete clutch leverass including cables to reverse shaft & park brk . installed CR250 cluth perch & lever & Wb park brk block off . then i pulled reverse shaftlever all the way back double safety wiring it & finally connecting wiring .She has reverse & very easy clutch pull .
badgerboy1
Sep 26, 2017 06:11 PM
