2 stroke Reeds question
Old Nov 29, 2005 | 12:24 PM
ShadyRascal's Avatar
Default 2 stroke Reeds question
Doing some mods again on our Blaster. I'm looking at aftermarket reed cages but here's my question: Why not use aftermarket reeds on the stock cage? Do the aftermarket reed cages flow enough more to make it worth while?
This Blaster is ported and has a 30mm carb. Going to a 34. Hate to spend 150 bucks on a reed cage and find that 30 dollars for reed petals on the factory cage is about the same. We ride dunes so wide open throttle riding is predominant.
thanks,
SR
Old Nov 29, 2005 | 12:33 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
thanks,
SR
I have had pretty good luck with just going to Boyesen Reeds. I have never bought a new reed block but from what Ive read they do make a difference. I just dont know how much i trust the opinion of a mag who gets a bunch of free stuff to test every month.
Old Nov 29, 2005 | 01:22 PM
4FITTY's Avatar
V FORCE
Old Dec 2, 2005 | 12:32 AM
ZillaRider02's Avatar
Aftermarket reed cages typically have a larger surface area(Which means more air flow). If you were running a stock carb, I would say stick with the stock cage. I put a Boyesen Rad Valve on my ported 250R and it did make a big difference (Better throttle response, etc). I would say check E-Bay for a used Rad Valve or V-Force reed setup.
Old Dec 2, 2005 | 11:19 PM
Six2notScaredofU's Avatar
I replaced the stock reeds on my shee with Boyensen Dual stage Reeds made a big Diff. I Plan on getting V-Force Reed Cages Soon.
Old Dec 3, 2005 | 12:34 AM
derbyking's Avatar
shady put a v-force on it.thats what i have on our bolt on 03 blaster and it seems to work great,matter of fact reeds and a toomey exahust and itll haul me up crapo.ive seen quite a few banshee reed dyno charts and the v-force always wins out a hp or two
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
Anomers
Aug 16, 2015 11:06 AM
Bergmann
Aug 13, 2015 03:51 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
