19cc Domes on pump gas??
Old Nov 1, 2000 | 01:43 PM
RippinShee's Avatar
I found a cool head in great condition for 200 bucks. It comes with 19cc domes. Can I use this on my stock 2000 Banshee with pump gas @ sea level??
Old Nov 1, 2000 | 02:26 PM
Zorro's Avatar
I don't think so.
I'm not a professional, so wait and see (rather read) some experienced guy's replies.
However, I don't think a 19cc dome will run on pump gas. On dirtwheels, they tested a banshee with 22cc domes and ran race gas. I've read that 20cc is the minimum.
Old Nov 1, 2000 | 07:13 PM
blue_banshee's Avatar
i would say that 20cc is about the lowest you should go AT sea level, i know others will disagree that prolly live above sea level b/c as you go up in altitude the compression lessens. u can buy domes for about 60-70bucks, maybe u can get the guyu to drop the price a lil bit and sell u just the head without domes and get different size domes, 20cc, 21cc or 22cc...unless u feel like running race gas, also as you go up on the compression(goin down on dome sizes) u may consider having your crank trued and welded to prevent the crank to split in the future. but yes you can use the coolhead with a stock motor.
Old Nov 4, 2000 | 12:24 AM
free1steven's Avatar
Here in Colorado the octane for premium pump gas is 91. I ride at 5000 ft. altitude. I cannot run the 19 domes without at least a 50/50 race gas mix. Runs best with 100% race gas. My compression with a stock cast piston was 140psi. Compression now with a Vito's forged piston is now at 155psi.
Old Nov 4, 2000 | 09:40 PM
Rob4092's Avatar
Very cool Website upgrades!
They looked great!
Are you headin' down to Rocky Pointe for Thanksgiving?
Old Nov 5, 2000 | 05:48 PM
peewee's Avatar
i run 19cc domes and i live at 3200 feet. i have had absolutely no problems the machine runs great. i have around 139 for compression. i wouldnt worry about using race fuel unles your compression starts getting over 150. i run 91 octane
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
