rpm stuttering I need help bad
Old Feb 3, 2006 | 09:04 PM
yfz450sandman's Avatar
Default rpm stuttering
my yfz 450 has been sick for a long time. when i push the throttle in and go it dose alright in first gear but when i go through all the other gears it starts to stutter when it gets high rpms and eventialy quits and then it starts right back up no problem Ive jetted it all the from 140 to 185 and it still does the same thing and quits it also has an stage 2 dyno jet kit performance exhaust and K&N.
Old Feb 4, 2006 | 09:59 AM
rapadap's Avatar
Default rpm stuttering I need help bad
I would check the ignition.
Old Feb 4, 2006 | 06:55 PM
89exrider's Avatar
It could possibly be timing. It might have jumped time causing it to miss at higher rpms. Also check all of your wiring to see if maybe a wire to the rev box might be messed up.
Old Feb 5, 2006 | 12:21 AM
Ive tried thos things but it still dosent work right
Old Feb 7, 2006 | 11:23 PM
freedomintheskies's Avatar
If it were my ride, I would check the fuel filter and the tank vent.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Sammich
Feb 4, 2006 11:50 PM
ChewyR
Jul 28, 2005 05:40 PM
SlimLine
Jun 19, 2003 07:50 PM
