Warrior Mods.
Old Aug 4, 1999 | 02:00 PM
MXrider's Avatar
Hey I want to modify my 1996 Warrior but i dont want it to cost me a arm and a leg. What are some mods that can make me go faster but still have enough low end to ride wheelies. What would happen with a 14 tooth countershaft sprocket?
Old Aug 4, 1999 | 07:39 PM
1BadWarrior's Avatar
Check with Golden West Cycles they have Performance Kits for Warriors.
Old Aug 14, 1999 | 04:18 AM
Darrin's Avatar
If you go a tooth bigger you will get a little more top end. If I was you save your
money and get a pipe & filter package.
I have an E series pipe,a K&N filter, rejetted carb,and a White Bro. torque stuffer
in the head pipe. You should be able to do
that for under 3 bills. Speed ain't free.
The White Bro pipe is pretty loud if noise is
a problem get Super trapp IDS I have heard
they are a little better. I'm waiting an a
cam for my Warrior right now,the pipe and
stuff helped but It's time to do set the
valves so I figured why not stick in a mild
cam in the process. I run a 14 tooth front
sprocket and the mods help keep that low
end grunt you like.
Darrin
Old Aug 18, 1999 | 05:49 PM
ZORLOC's Avatar
Darrin
what is this Torque Stuffer ?
how much is it ?
and how does it install?
I have the E-series muffler and a K&N filter already (almost the same set up cool)
Thanks for your time
Chad "ZORLOC" Petersen
96 Yamaha Warrior K&N, Shock wears, WB E-series, AMP Link, Lone star Axcaliber axle, Realtor tires. 97 Yamaha Blaster FMF Ram valve, Bandit rear tires. 97 Yamaha Waveventure 760 STOCK 99 Dodge Ram 1500 360 4x4 ex-cab
Old Aug 19, 1999 | 10:57 AM
Harold's Avatar
A torque stuffer helps the flow of exhaust gas from the head, remove the headpipe and install the stuffer in the headpipe(gently hammer it in until seated) cost about $38.00.
Old Aug 20, 1999 | 02:11 PM
thumper4x4's Avatar
Sorry I believe a torque stuffer restricts exaust to increase back pressure slightly, To increase low end torque.Very good for slower trail riding and hills. But you will loose some top end.
Reactant
Mar 30, 2022 02:08 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
JakeXBL
Sep 5, 2015 01:08 PM
