starting question
Old Mar 4, 2007 | 09:03 PM
Raptor660JC's Avatar
Default starting question
02 Raptor 660
When I was running the stock clutch lever and perch, I was able to start my quad in any gear as long as I had the clutch engaged. I swapped the stock lever and perch with an aftermarket lever and perch and since then I am not able to start my quad unless I'm in neutral. Does this have anything to do with those 2 electrical wires on the stock perch?
Old Mar 4, 2007 | 11:59 PM
Doctorturbo's Avatar
GOT BOOST!
Yep, sure does.
Old Mar 5, 2007 | 11:01 AM
What are those 2 wires? Is there anything I can do to fix that or am I SOL? Thanks
Old Mar 13, 2007 | 10:03 PM
cluby's Avatar
You could tie those two wires together, but then it will start with out the clutch engaged
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
kwackermann
Jun 24, 2015 10:18 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
