warrior silencer
Old Jan 8, 2008 | 11:36 PM
warrior21's Avatar
Default warrior silencer
i am wanting to buy a slip on silencer for my 2000 warrior but i dont know what to do. do all i have to do is take off the stock silencer and slip the new one on or do i have to buy the exhaust from the motor back then put on the silencer
Old Jan 9, 2008 | 12:01 AM
ctateusa1's Avatar
no all you will have to do is pull off the stock silencer and install the new slip on.
Old Jan 9, 2008 | 12:15 AM
warrior21's Avatar
ok thanks so i wont need a mid pipe then
Old Jan 9, 2008 | 10:21 AM
ctateusa1's Avatar
no you would really have to improve flow a lot to need a different mid pipe(or have your rust out on you)
Old Jan 9, 2008 | 05:26 PM
warrior21's Avatar
the mid pipe if fine. i thought you have to buy a longer mid pipe bc the stock silencer is larger
Old Jan 9, 2008 | 10:45 PM
recon99's Avatar
You will also have to rejet the carb if you want any real power gain. To get maximum power you need the air/fuel ratio at a certain point. When you allow more airflow with the exhaust, you also need to put in a bigger jet and get more gas into the engine. Aside from not getting a power gain, running too lean can also cause engine damage because of the excessive heat.
Reactant
Mar 30, 2022 02:08 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
