Warrior carbs
Old Apr 10, 2008 | 03:34 PM
pmcc37's Avatar
Default Warrior carbs
<a target=_blank class=ftalternatingbarlinklarge href="http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=&store=Main&catId=111&productId= p16259&leafCatId=11101&mmyId=6564
">http://www.denniskirk.com/jsp/...1101&mmyId=6564
</a>
or
http://www.denniskirk.com/jsp/...CatId=11101&mmyId=6564
Old Apr 12, 2008 | 12:13 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
The one carb is a 38MM but the other one does not say? I would get with a local engine builder who does dyno work on the warriors and ask his opinion someone like that can give you good solid #'s on what to expect. I know when I went with the TM 48 on my DS650 build it made a huge differance. Hope this helps you.
Old Apr 14, 2008 | 10:22 AM
pmcc37's Avatar
I've been told to go with the edlebrock buy more than one person, but if i can save $200 it would be nice
My local parts guy siad the eldebroke and told me where to get it cheaper than from him, which turns out was only $15...
Anymore opnions? or suggestions????
Old Apr 14, 2008 | 07:00 PM
recon99's Avatar
In my opinion, just keep the stock one. The cheap aftermarket ones ($200 range) do not have accelerator pumps, and I really wasn't that happy with my edelbrock for the reason that the dumbasses didn't work a choke into the carb design. That's right, almost $400 for a carburetor and you can barely get it to start in cold weather. Other than that the edelbrock is great, it performs well and is very easy to tune, but I wouldn't buy another one.
One common thing is to get a z400 carb instead of an aftermarket one. It takes a little more work to get it to fit and tune it right, but you're getting a great performing carb for about half of what the cheap crappy aftermarket ones cost. If you want more info on this I can give you a link to a great website that will be able to help you out.
Old Apr 15, 2008 | 09:45 AM
pmcc37's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: recon99
One common thing is to get a z400 carb instead of an aftermarket one. It takes a little more work to get it to fit and tune it right, but you're getting a great performing carb for about half of what the cheap crappy aftermarket ones cost. If you want more info on this I can give you a link to a great website that will be able to help you out.</end quote></div>
No choke, thendiffinately not getting one. I saw something on the z carb, but was a lil leary, if you have a link that would be great.
thanks
Old Apr 15, 2008 | 05:25 PM
recon99's Avatar
http://yfm350.proboards31.com/...on=display&thread=4333
Old Apr 20, 2008 | 09:21 PM
Paulie1959's Avatar
recon99 is right, the stock carb, is not that bad for performance but if you have to, get a 400 carb (mikuni BSR 36) from a suzuki, kawaski, or even a Raptor 350 ther the best for your 350 motor, now ther not much of a performance gain, I would put my money on a intake kit, pipe, more compression, and front shocks.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
