Need Help! Stripped Drain Plug!
Old Sep 11, 2008 | 08:42 PM
Triggerfreak's Avatar
Default Need Help! Stripped Drain Plug!
Well i went to drain the trans/crank case on my 88 honda trx250r four wheeler that i just purchased and the drain plug ifs fn stripped.Now it wont loosen any more or even tighten so it is leaking oil on my now.How do i go about fixing this properly with out having to pull the motor or spend a but load of money.Thanks!
Old Sep 12, 2008 | 08:24 PM
ss97's Avatar
Lets Ride!
Perhaps you can fix it with a Heli-coil tap and drill kit...... I've used those kits in some tough places and they seem to work pretty well...... I'm not sure how well they would seal in the oil but I think it would probably work as long as the oil is not under a lot of pressure.....
If not that I've heard of people using rubber plugs but I'm not sure how that works....
Old Sep 16, 2008 | 08:37 PM
lost-it's Avatar
most auto parts stores carry oversize drain plugs in metric sizes... first time put grease on the new plug run it it, and pull it out, and wipe the grease off.... the grease is used to catch the metal shavings made by the new plug in cutting new threads... then re-install... hope this helps
Old Sep 16, 2008 | 08:50 PM
Got it fixed.Got the old plug out and put in a oversized self tapping drain plug.The idiot before me has a coarse threat bolt that he cut off and ground down to fit and put some jb weld on it and jammed it in.
Old Sep 18, 2008 | 02:58 AM
user493's Avatar
Moto Psycho
OMG. LOL.
Old Sep 23, 2008 | 10:26 PM
Bob427's Avatar
wow, cant wait to ear how he fixed other problems on the quad...
I would have used an helicoil with a brass taper washer but I didnt know about oversize self tapping drain plugs... now added to my notes.. the grease trick too [img]i/expressions/face-icon-small-smile.gif[/img]
SDR-II
Sep 29, 2015 01:06 AM
Polaris5
Aug 29, 2015 09:11 PM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
