Trying to build a 90 atv
Old Dec 10, 2008 | 06:51 PM
kfxgirlrider's Avatar
Default Trying to build a 90 atv
I am trying to build a little 90 atv from the ground up with my dad. I need tips on how to get started...
Old Dec 22, 2008 | 08:56 PM
raptor#420's Avatar
get a frame.. [img]i/expressions/face-icon-small-tongue.gif[/img] then a motor that fits in the frame.. (i would go with a 125 giovani* pit bike engine (there farly cheap new..)
Old Dec 27, 2008 | 01:45 AM
this guy's Avatar
Is this for a racing application? Are you asking about restoring a 90 from the ground up? Background information and detail helps us to help you make better informed decisions and more accurately answer questions.
If this is a true "from the ground up" project then the first thing you will want to do is to decide what you want to do with this ATV. This will determine what components and set up you will want. Another thing to consider is what your budget is. Personally I do a lot of frankenstein 3 wheelers on a very small budget and have a fair amount of quadMX experience so I will try to help you out the best I can. There are a number of very good resources here on the forum that should get you in the right direction.
Good luck and happy building.
Old Jan 2, 2009 | 09:47 PM
I am truly building this thing from the ground up!!! I am wanting to make it a pretty fast like a racing one on a pretty small budget.
Old Jan 21, 2009 | 08:38 PM
tedsxb's Avatar
Well, I would first suggest you take a look at some of the ready built race 90s that companies like Cobra and Lem make. Take notes on how the frame is designed. You are going to want to have a WIDE, stable frame and axle/a-arms. Then, I would go with a 90cc or similar dirtbike motor because most come with manual transmissions and are a bit more powerful.
Old Jan 21, 2009 | 08:44 PM
scootergptx's Avatar
Supersock
Hired Gun!
I can see this would be a good father/daughter project.
If it were me, the frame would be my biggest concern. You can pretty much build any motor, but if the frame can't take what it puts out, or what you put it through, you're sitting back in the garage.
Old Jan 31, 2009 | 02:45 PM
Beastly 3hundo's Avatar
Well to start out, you should try to find a used trx90 frame and then weld in a gusset kit. Theres a person on ebay who sells 300ex a-arm and shock kits for trx90s. What kind of engine are you planning to use, 2 or 4 stroke.
Old Feb 4, 2009 | 06:46 PM
hotblooded's Avatar
We took a YZ85 motor and put it in a Blaster chassis. It really was a fairly easy fit, we had to drill out the swing arm bolt hole on the motor and go with a smaller front sprocket because of clearence and mount the radiator. The chassis is maybe a little heavier than the others but the thing handles like a dream.
Old Feb 8, 2009 | 08:32 AM
LT80's Avatar
LT80 Expert
I'm w/hotblooded.
I did the same except w/honda motor.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
Minimod
Sep 10, 2015 08:03 AM
awer1968
Sep 8, 2015 11:02 AM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
