warrior conversion
I have been wondering if it could be posible to but a yz426 top end on the Warrior's bottom end. The only poblems I can think of are:
The bolt patterns
Going form single cam to dual cam
Rerouting the oil flow to make them match up(might have put some oil hoses in to get them to match up)
Getting a rod that will match up to the yz piston and warrior crank
Case mod might be needed prevent piston/rod from hitting it
Mounting of radiator on a Warrior frame
It would be asome to have a 426 6 speed w/ reverse.
If you do get some thing built let me know,
I would be very interested.
Chris
The bolt patterns
Chris
<< I have been wondering if it could be posible to but a yz426 top end on the Warrior's bottom end. The only poblems I can think of are:
The bolt patterns
Chris
[img]i/expressions/face-icon-small-shocked.gif[/img]
That would be tricky to say the least!
