2002 500 Sportsman - Fan won't come on
Old Jul 13, 2011 | 10:07 PM
COCJ's Avatar
Default 2002 500 Sportsman - Fan won't come on
My fan won't come on and machine overheated. Any ideas before I start tearing things apart? Is there a fuse somewhere?
Old Jul 14, 2011 | 07:02 AM
Kerbbirds's Avatar
I believe the temp sensor is behind and towards the top of radiator on your machine, unplug sensor with key on and fan should run, if not hook 12 volts to fan and see if it runs, if it does, sensor is bad ,if it does not, fan is bad,
Old Jul 14, 2011 | 08:25 AM
TLC's Avatar
TLC
Frist check you fan, I uses two jumper leads from a 12V batter to the two fan wires and found out my fan was shot.
The thermal switch that tell the fan to come on is screwed in the bottom corner of the rad. Check if its two wires are broke or disconnected before replacing.
If you Switch is like mine a Polaris which I think it is. Part Number 4010161
these thermal sensors from a auto parts store will work, you just have to spice your old sensor's wire plug in connection on the end.
Napa FS147
Wells SW526
Blue Streak TS-127.
or any sensor for a 84-88 Nissan Maxama or 86-89 Nissan Stanza will work.
If you need a fan do not get one from a dealer, there built by a company called "Spal"
I think your fan is a Polaris Part#
2410123 like mine and my dealer wanted $320 Canadian,LOL Spal sells them for $79 heres there link
SPAL USA
I got this 9" Spal 30100442
Model VA07-AP8/C-58A
Took 20 min to change the fans.
SPAL USA
Old Jul 14, 2011 | 04:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
also check to see if any thing like a twig,rock is stuck in it stopping it form spinning. it doesn't take much to stop them.
Old Jul 15, 2011 | 06:40 PM
COCJ's Avatar
Thanks for your help guys! Sensor is bad. Dealer wants $69.53 for a replacement. Might try the NAPA part. Radiator cap doesn't look great so I want to replace that, too. Dealer wants $39.00 for a friggin' radiator cap!
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
