Rear drive shaft repair
Old 10-06-2011, 07:12 PM
NHOJ_28500's Avatar
Default Rear drive shaft repair
On my 2006 Sportsman 700 efi I need to change the u-joints on my rear drive shaft. But I cant figure out how to get the rear driveshaft off to change them cause it has no slip yolk. How do you get it off? Thank you
Old 10-07-2011, 05:51 AM
If you are talking about the shaft between the transmission and and the rear gear case,you remove the roll pin from the transmission end of the shaft and it does slip back toward the rear gear case a little on the splines,BUT not enough to remove it from the atv! You have to move the rear gear case back a little to remove it completely! The manual never actually tells how to service the rear prop shaft itself (only how to remove the transmission and rear gear case)but this is the best way! It only mentions the shaft when the trans is pulled and even then it says to move the rear gear case back!(I never had to) Not a fun job! Be sure to grease the rear splines when you install back in. OPT
Sandman2.0
07-21-2015 09:03 AM
ghost civic
07-15-2015 10:48 PM
joeyupton
07-14-2015 11:51 AM
tporath
07-11-2015 12:31 PM
rcappie4
07-10-2015 04:54 PM
Quick Reply: Rear drive shaft repair
