2006 Polaris Sportsman 500 EFI T-Bap wiring
Old 07-26-2012, 09:34 AM
GFronk's Avatar
Default 2006 Polaris Sportsman 500 EFI T-Bap wiring
I recently purchased the upgrade wiring harness off ebay for the T-bap and realized I made a huge mistake. I did not diagram which wire goes where when I disassembled our previous attempt to "fix" the wiring . I do not have access to a diagram and was wondering if anyone knew which wire goes to which post . It is the three wire harness that mounts to the T-bap sensor. Thanks for any help.
Old 07-26-2012, 01:43 PM
Welcome to the forum! If the repair connector wires are not the same color,I believe the colors (from the right side of the connector) are orange, violet, then pink. Hope this helps. OPT
Old 07-26-2012, 02:10 PM
GFronk's Avatar
absolutely awesome...thank you! I have had so many problems with this Polaris from no spark to shorting wires. Engine is strong, but the wiring has been kicking my butt! Thank you for the quick response. Back out to hook that up and I should be running!
Old 07-26-2012, 04:41 PM
GFronk's Avatar
Well, it all went together great. Check engine light is off, and quad runs smooth. Thanks again.
Old 09-29-2020, 06:17 AM
johnmatheny733@gmail.com's Avatar
Default Tbap pigtail
Hey bud can you send me the link for the tbap wiring? I can’t find it to save my life.
skittero
35
03-01-2019 12:39 AM
neilbedwell
11-10-2018 11:02 AM
bikedad3
06-29-2015 08:58 AM
yellowpolaris
06-21-2015 11:13 AM
05-27-2015 11:15 AM
Quick Reply: 2006 Polaris Sportsman 500 EFI T-Bap wiring
