2003 polaris sportsman 600 twim
Hello
I have a 2003 Polaris sportsman 600 twin and it is stuck in four wheel drive I have changed the front gear case fluid with demand by Polaris
I took the gear case apart and nothing looked bad or broke the only thing that look questionable was what Polaris calls the Roller Trust Bearing it looked bent I took a socket and was able to get it back to its shape all needle bearings seem to be ok I also tested the power from switch to gear case no problem any one have any idea
I'd look close at the roll cage itself for any fine cracks. The plastic roll cage #36 and warped armature plates #37 were the most problem areas.After market replacement aluminum roll cages are available now along with some have used John Deere parts. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
John deer part #s
Roller Kit MIA 10666
Cage kit MIA 10667
Seal kit MIA 10654
armature plate MIA 10656
Thrust bearing and washer MIA 10663
John deer uses same diff in the Gator
__________________
John deer part #s
Cage kit MIA 10667
Seal kit MIA 10654
__________________
bzdok1234
30
Feb 23, 2016 01:55 PM
