polaris srambler loose solenoid in axle hub?
Old Apr 2, 2014 | 08:36 AM
chevypow's Avatar
Default polaris srambler loose solenoid in axle hub?
Hey guys, great site! I have a 2000 scrambler 400 awd. The front left wheel had alot of slop even though the wheel bearing nut was tight. At closer examination the part of the front hub where the bearing races tap in is loose in the housing letting the axle move in the housing. The wheel bearings are not the problem i can move the whole solenoid end of the lower shock housing. So my question is does that need replaced or what holds it together? Thanks in advance for any help.
Old Apr 2, 2014 | 09:29 AM
If you have slack in the strut,probably worn cv joint allowing back and forth play. Check in and out play in the front strut from the shaft,then check the strut itself for any damage. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse http://www.cyclepartswarehouse.com/f...2000&fveh=5497
Shifts
14
Jul 13, 2015 08:41 AM
Chocobamofo
Jul 10, 2015 07:46 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
Rider252
Jul 6, 2015 03:37 PM
tweeder
Jul 5, 2015 01:57 PM
