2010 sportsman 500 blinking battery indicator
Old Sep 16, 2015 | 08:30 AM
These year models use the same speedo.
Speedo Part # 3280528
Year Product Model Assembly
2012 ATV SPORTSMAN 800 EFI 6X6 ELECTRICAL, GAUGES and INDICATORS - A12CF76AA (49ATVGAUGES08SP500)
2012 ATV SPORTSMAN FOREST 800 6X6 ELECTRICAL, GAUGES and INDICATORS - A12CF76FF (49ATVGAUGES08SP500)
2011 ATV SPORTSMAN 800 EFI 6X6 ELECTRICAL, GAUGES and INDICATORS - A11CF76AA (49ATVGAUGES08SP500)
2010 ATV SPORTSMAN 800 EFI 6X6 ELECTRICAL, GAUGES and INDICATORS - A10CL76AA (49ATVGAUGES08SP500)
2010 ATV SPORTSMAN 500 HO ELECTRICAL, GAUGES and INDICATORS - A10MH50AJ/AX/AZ (49ATVGAUGES08SP500)
2010 ATV SPORTSMAN 800 EFI ELECTRICAL, GAUGES and INDICATORS - A10MH76AJ/MN76AX/AZ (49ATVGAUGES08SP500)
Old Sep 16, 2015 | 10:04 AM
speedbuff's Avatar
I found a problem my input ignition voltage to the head is reading about 12.5 volts machine running the battery voltage wire at the head is at 14.4 .I jumped in some battery voltage to the ignition voltage wire to see if that would turn the light out but no luck .Do you happen to know where in the harness the ignition red/white splices are I would like to do some voltage checks there
Old Sep 16, 2015 | 01:12 PM
Red/white is the most common wire through out the harness.You should be showing this 14.4 volts that is coming from the charging system as this is one of the functions of the speedo to display that the charging system is operating properly.If you still feel it's a wiring problem and not the speedo itself there are several junction blocks that the red/white wires tie into and branch out,but it involves a lot of digging through the harness.
Old Nov 11, 2020 | 10:16 AM
jjb1983's Avatar
I was wondering if you ever found out what was causing this. I have a Sportsman 800
that has the same issue. Good battery, charging at 14.3 but battery light flashing and diagnostic mode on the speedo cluster shows 3-3.5 volts key on or engine running. I looked at the schematic and there is no dedicated wire to the speedo that controls that light. It makes me think the speedo is bad because I have battery voltage at the red wire and red/white wire going into the speedo. Thanks
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
