95 Polaris scrambler reving problem.
Old Oct 9, 2016 | 04:42 PM
spdshop's Avatar
Default 95 Polaris scrambler reving problem.
95 scrambler 400 idles fine but when reving the engine up it wants to runaway.sprayed starting fluid all around base and head gasket area around reed area and carb no reving up.only place I haven't checked is around crank seals any more ideas.
Thanks
Old Oct 9, 2016 | 07:10 PM
Crank seals or to lean main jet,but from what I went through most of the time it was the crank seals especially the one behind the drive clutch. Had several like this that were jetted correctly and would idle ok but race off idle. IF the machine is new to you best to check the jetting any way. 30 pilot jet,240 main was stock but some would lean them up a tad to a 230 main jet at least down in our area(around 600 ft above sea level) to keep them from being too boggy.Polaris set them up too rich from the factory really on purpose. They knew what people would do with them. Depends on what altitude you're at and temperature too on correct jetting.
Old Oct 9, 2016 | 08:08 PM
spdshop's Avatar
I believe I have a bigger main in it.it also has a Dynaport pipe along with a reed spacer plus I believe the cylinder has some port work done as well.can I spray around the crank seals with the clutch still oneed or do I need to remove them and the backing plate.
Old Oct 9, 2016 | 08:18 PM
You can try to spray down into the backing plate area and see if you notice a change in engine speed. If you remove the clutch cover and backing plate might as well replace it any way since you're already there.
Old Oct 9, 2016 | 08:23 PM
spdshop's Avatar
Is it fairly easy to replace that side.I have the clutch puller.and I think the secondary clutch is just a bolt.how hard is the other side to change?it assume the fly wheel answer all has to come off.and need the special socket.
Thank you for all your help
Old Oct 9, 2016 | 08:37 PM
Need a harmonic balancer puller for the flywheel. Mark the stator plate and case and remove the plate. Seal just pops out like the pto side. Look at this video on a 700 flywheel. Same way on pulling all the flywheels. Start at the 3:50 mark.
can-amsledder
May 15, 2020 10:54 AM
pinchvalve
Aug 29, 2016 03:01 PM
drm50
Aug 29, 2016 02:45 AM
r1nsho
Jul 29, 2016 12:54 PM
Paintman
Jul 20, 2016 09:02 PM
