Hey Stendori (front spacer post)
Hey, I'm wondering how the spacers affected the ride and was there any clearance gained?
I have an 06 SP 800 that I'm doing tons of work to and when I read your post last year or so i wanted to do it. my front wheels look as if they lean in from bottom to top. from the front / \ Now i have or am changing the tie-rod ends, wheel bearings, ball joints and ordering 2 new black rubber bushings that go up in the springs.
But, my way is not with PVC it is actually whats left of the wheel bearings from the rear wheels i believe. Anyway the outside of the bearing is almost perfectly fit to do the same task. Ill let you know on that.
Thanks
Thanks
as far as the ride goes, it makes the front end sit up higher, but to me not enough that it effected the handling(maybe a slight stiffer ride in front)on either of the bikes I did( 4 of them I think). there was no rubbing issues at all. I used pvc as it would not have any metal on metal earing from just riding vibrations on rough terrain. Plus it was an inexpensive and quick fix to the sag.
JackTheKing
07-14-2015 09:09 PM
