Drive Belt Continues to Rotate Secondary at Idle
Old Jan 12, 2013 | 10:17 PM
Sportsman44's Avatar
Default Drive Belt Continues to Rotate Secondary at Idle
I have a 2009 RZR with 300 hrs on it. When I purchased it from original owner, it had 125 hrs. on it. Anyway, last time I drove it I noticed the EBS wasn't working as well as usual. Then next time I needed to shift, it would neutral but was in a slight bind. Then going out of neutral tranny grinds. I have to kill, put into gear then start to keep from grinding.
Purchased new belt and pulled off the cover today. Tested with old belt first, secondary continues to rotate at idle. Placed new belt, same issue. I can stop the Secondary with my boot, but it just starts rotating again when I remove my boot. The Primary has maybe 1/16 inch free space between sheeve and new belt edge. Also, I guess the original owner put on a "Rapid Response" Secondary Pulley (don't think that is stock). Don't know if that will make any difference?
Any suggestions apprecated.
Tim
Old Jan 13, 2013 | 10:00 AM
Are you using an oem belt? Some after market belts are wider and can cause creeping problems. OPT
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
trouttracker
Jul 20, 2015 11:54 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
