2012 Ranger 400 - Mystery Tube
Riding out to check on pastures the other day and noticed a clear, 1/4" poly tube about 2 feet long laying on the ground. Had to come off the Polaris but I can't seem to figure out where. As a side not I have noticed a little bit of a gas smell and small amount of leakage on skid plate.
Any ideas? Drain line off of carburetor? Part diagrams don't show anything.
Thanks.
Thanks.
Look at the bottom of the float bowl. Has a small over flow/drain nipple that the hose hooks to.Parts lists don't always show drain lines.If you're smelling fuel,the needle and seat may be leaking,over filling the carb and running out the over flow tube. Might be time to install a good carb kit.https://www.ebay.com/itm/Shindy-Carb...=mtr#vi-ilComp
