predator jetting question
Old May 18, 2003 | 11:11 PM
  #21
colopred's Avatar
Default predator jetting question
Thanks guys, I guess I'll try a 170 first then maybe back down to 160-165. I'll keep you posted - I should have it installed by Thursday this week. By the way, I have never messed with a carb before - can someone give me some tips on changing the jet.
Thanks,
Jeff
03 PRED
W/B slip on
39 tooth rear sprocket
PRM radiator scoops
shock covers
Old May 18, 2003 | 11:20 PM
  #22
modquad's Avatar
First, turn off the gas. Looking in from the left side of the machine (viewed like you're sitting on it) on the bottom of the carb there's a small diameter hose...smaller than the other two, they're the vents. Just above that is a bowl drain screw. Back that off an wait til you don't see any fuel running through it anymore...you can catch it in a container if you like. Loosen up the clamp on the front of the carb, the one hoding it on the rubber intake boot. Wiggle the carb back and forth til it's free. I normally take off the fuel line to gain a little more movement. Now, like JJ had posted earlier, those carb bowl screws really like to strip. You can take a small Vise-grip to clamp on and break them loose before you try the phillips head approach. Get the replacement screws like he suggested, w/ lockwashers, and or loctite. Once the bowl is off, you'll see the main jet.
Old May 19, 2003 | 07:00 PM
  #23
colopred's Avatar
Great!
Thank you Ken, as always very helpfull. I'll keep you posted on how this effects the performance.
Jeff
03 PRED
W/B slip on
PRM radiator scoops
shock covers
Old May 20, 2003 | 01:28 PM
  #24
modquad's Avatar
You're very welcome Jeff. I think...er, I know you'll like it. Zoom, zoom. [img]i/expressions/face-icon-small-happy.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
