little compression after rebuild
Sounds like you definitely need to be looking elsewhere for the problem. If you done all that and it still doesnt read more, there must almost certainly be a crank seal problem or something like that. NC, you went from DJ man to hit man.LOL
Pita, go down to your local Honda shop and buy a tube of Hondabond. That is all you need for the case halves. There is another product called threebond which looks and acts the same as Hondabond. I know guys that use that as well. Good luck on the motor.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
250, 550, 90, atv, compession, compression, endgap, heads, loss, polaris, psi, rebuild, ring, shaved, trailblazer
