Loose Steering Stem Rivets
Old May 16, 2000 | 04:31 PM
RobCulp's Avatar
I just noticed the rivets are loose that hold the bracket at the bottom of the steering stem on my 3 week old Scrambler 400 2x4. Has anyone else had or noticed this problem?
Old May 16, 2000 | 04:49 PM
Rammer's Avatar
Now that you mentioned it, my Xplorer did that too. Take it to the dealer, he'll knock out the rivets and install small bolts and nuts.
Old May 16, 2000 | 05:14 PM
stevie's Avatar
You might as well just order a hsp stem and backet the stock ones are trash
Old May 16, 2000 | 06:53 PM
jad's Avatar
jad
Can you provide a number or web site for HSP?
Old May 16, 2000 | 06:57 PM
TheQuadfather's Avatar
The same thing happened on my 99 Sport, I replaced it with an HPD brass steering post bushing, $35. The difference was incredible. It is quite tight for the first hour or two of riding. It is actually a bearing, not a bushing. It's very easy to install. RcR has them, you can call them at 618-644-3211
Old May 16, 2000 | 06:58 PM
Old May 17, 2000 | 12:32 AM
GJ's Avatar
GJ
Mine were loose from the show room floor. but I was expecting that after reading up on them. what I wasnt expecting was the was how weak the steering stem is. It flex's and twists like a wet noodle. It will eventually be replaced with the hotseat stem along with the silly lower bearing.
Old May 17, 2000 | 09:38 AM
stevie's Avatar
The site is www.hotseatperformance.com
Old May 17, 2000 | 05:29 PM
Mike Chero's Avatar
Rob,
I've just replaced the steering stem bearing on my Trailblazer. It was a lot of fun. Many magic four letter words were uttered by me in order to get it to fit. You'll need a 90 degree angle drill to drill out the rivets. If you have a machine with a radiator, lots of luck, you'll have to remove it along with the tie rod bolts and the upper steering post bearing bolts.
Old May 18, 2000 | 10:01 AM
jad's Avatar
jad
My steering was loose from the begining also. 2000 Srambler 1 month old. I thought is was normal play until I read this. I looked at it yesterday. I can not belive Polaris puts together a heavy well made machine and uses small rivets to hold all the stress of the steering. Stupid. Mike says that it is a bitch to put the after market bearing in. I am wondering if I should just get the bolts put in mine. I need to see how much the stem is flexing first. If it is as bad as you guys say I will do it. How much is the stem and bearing?
