scrambler tip over question
Old Jul 14, 2003 | 10:17 PM
vampirerider's Avatar
Default scrambler tip over question
OK, my girlfriend was doing doughnuts on a '01 scrambler and lost it. She tipped it on its side. It was running like that with gas......AND OIL running out of it. When i traced the oil, it was coming out of the air box. That seems strange to me. Can anyone explain?
Old Jul 14, 2003 | 11:49 PM
GM's Avatar
GM
i have had this happen to me and my friends have it happen also. I believe my dealer mechanic said it comes from the crankcase. Feel free anyone to correct if i'm wrong.
garret~
Old Jul 15, 2003 | 12:06 AM
Thanks for the reply. Now the question becomes ( cause stuff like this drives me batty till i know) HOW does it get from the crankcase to there. Heres what I am imagining: This quad is on its right side, almost upside down, idleing. Oil runs backward through the carb up the intake tube, through the air filter, out the box and down the fender WHILE THE THING IS RUNNING!?! If that is the case, how does it get from the crank case to the carb? As if you cant tell, I have NO idea how these engines operate. I have never been in one. I cant see any other way for it to get to the air box......an explanation will sure help me sleep better lol.
Old Jul 15, 2003 | 12:14 AM
GM's Avatar
GM
Yea, I don't understand this concept very much either and i work on cars a lot and stuff. But it is nothing to lose sleep over, and i'm sure if you relax someone w/more knowledge will answer you with the full conclusion to this and you'll be all better. So don't let it get to you. lol
garret~
Old Jul 15, 2003 | 01:07 AM
BigBadScrambler's Avatar
I personaly wouldn't worry about it. I have had oil get in my air box after doing wheelies and standing it on end to make the skid plates. However, I have no clue how it gets there.
Old Jul 15, 2003 | 01:31 AM
steve89's Avatar
I had this happen too, its from the vent hose thats attached to the bottom or side of the filter box.Its a common thing if you tip it over.After you clean up the box you should be able to see the hose.
Old Jul 15, 2003 | 09:21 AM
Ahhh! ok. a crankcase ventilation hose perhaps. Ill check that after work today... Thanks alot for the replies.
Old Jul 15, 2003 | 10:07 AM
NCScrambler's Avatar
Yes, Steve is right, it is a crankcase ventilation hose.
fordfaithful21
Dec 7, 2015 05:52 PM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
DeFox500
Jul 26, 2015 06:32 PM
