wHATS IS THE ALL TIME MUD TIRE
It all depends on what type of mud you are riding. If we are taking about the deep nasty black goo that doesn't have a hard bottom, then I would suggest keeping it in Low gear, put your right knee on your seat and keep the left foot on the floor. Keep your RPMs up about 3/4 to that if you need more you have it. DON'T STOP once you get going. Keep all your weight back over the left rear tire and slowly bounce your wieght up and down forcing the back left tire to grip as your weight comes down. Each time you come down you gain traction and when your weight comes up your tires clean. Keep the front end up so that the front tires stay up and don't bog. They will create ruts that clean the way for the back. They also create ruts that get you high centered so that is why you keep all of your weight on one sideand to the rear. Never let off the throttle. When your back left tire begins to bog and you loose momentum, then put your right leg on the right floorboard and your left leg on the seat. Switch your weight over to the right rear and start slowly bouncing to gain traction on the right side. This whole time you have to keep the throttle at 3/4 unless you feel like you need more power, and you must lean back a bit to keep the front end up. This technique is used in every competition I have ever seen in mud/water deeper than the racks and it has proven well for me. If you ever get in this deep or deeper, this is the way to go.
Muddy
Muddy
Since I only recently got my 4x4 I've just started to ride with some friends who like a lot of mud. This is their usual technique.
1) Ride into the mud until you're buried
2) Winch out (sometimes this requires 2 or 3 winches)
3) Laugh at each other's misery
4) Look for the next mudhole
The guy I mentioned above with the 28" Outlaws, says there fine on hard pack once your moving 10mph or so. He said the ride smooths right out.
#15
Give me a break blackwatwers are not thbat great for mud they suck.I would take them even if i could get a brand new set for a $100.THat's how bad i think they are.Well i would say the best 28's would be outlaws or vamps.DEpends what kind of mud.IF you want to find out go to www.highlifter.com and post about what is the best tire.
toonces
10-16-2019 12:11 PM
