Any major problems with the 400 engine?
Old Aug 10, 2003 | 12:57 AM
Wingnut55's Avatar
Default Any major problems with the 400 engine?
My machine is a 2001 Polaris Sportsman 400 with about 300 miles on it, I have owned it since new and have had zero problems with it so far. I was wondering what kind of luck other owners have been having with their 400 engines. Do they hold up very well? And are there any common problems that I should look out for? I plan on owning this machine indefinately, and I like to maintain things the best that I can. What kind of mileage can I expect to get out of it before it begins to wear out?
Old Aug 10, 2003 | 08:09 PM
95sport400's Avatar
Proper maintenance is the key to making anything mechanical last. Use synthetic oil and a quality filter (not Fram) and it should last indefinately. Even a properly cared for 2-stroke will last longer than you think. I just sold my 93 250 Trailboss and that motor was never touched and still ran like new.
Old Aug 13, 2003 | 06:25 PM
ftwflh's Avatar
What you have is a renamed 425 and I can tell you that it is one keck of a good engine!I have replaced the water pump seal once and adjusted the valves a few times but other than that it has been great.
neilbedwell
Nov 10, 2018 11:02 AM
toonces
Jun 30, 2015 11:19 AM
scaldwellk
Jun 19, 2015 05:08 PM
NONEtooSMART
Jun 17, 2015 08:48 AM
kevbowe
Jun 1, 2015 01:17 AM
