stearing post bushings for my scrambler
hey guys i need a new upper stearing post bushing for sure,but im not to sure if the lower one is bad also because my tie-rod ends are bad and all the slop i feel is comming from there..
im thinking chances are its probably bad or close to it seeing as how the upper is and the tie-rod ends also..think i should just replace it?hpd sells the lower bushing cheaper than the other guys.they say its for the 7/8 inch post,anyone know what size i have on my 02 scrambler 400 2x4?hpd doesnt sell a upper bushing huh?they dont list the online or in their catalog so im just assuming..thanks for the help,i really appreciate it
I have the HPD lower bearing on mine. It should fit. You can tell them what machine you have when you order it too. I THOUGHT that they updated the lower bearing on the newer scrams. Maybe not. When you move your handle bars look at the rivits (or screws) that hold the lower bearing on. If you see slop in those then replace it. Mine had rivits and those worked themselves loose. The new HPD bearing has screws.
When you go to drill out the rivets and drill the holes biger for the bolts take your tank off it makes the job alot easier.
Chocobamofo
Jul 10, 2015 07:46 PM
