Scrambler 400 4x4 1995
Old Aug 25, 2003 | 06:09 PM
savage21's Avatar
Default Scrambler 400 4x4 1995
i had a good ride this weekend but the scrambler kept quiting on me, maybe 2 hours or 5 minute after it quite it would do it again and i could save it from quitin by choking it and then un choke and gasing .i have had the carb. cleaners tand the jets cleaned , anyone got a idea?
Old Aug 25, 2003 | 06:56 PM
TrailBlazerguy250's Avatar
is your needle and seat sticking or brokin
Old Aug 25, 2003 | 07:08 PM
ftwflh's Avatar
Check your compression it could be getting low it needs to be at least 100psi or better.
Old Aug 25, 2003 | 08:51 PM
savage21's Avatar
how do i check the compression and how do i check needle and seat?
Old Aug 25, 2003 | 09:32 PM
ftwflh's Avatar
get a gauge,take out the sparkplug,hold or screw the gauge into the hole,has to be air tight,crank engine over a few times,read gauge.Will run at 100psi but not too good and will be hard to start when hot,should be in the 120psi range.
Old Aug 25, 2003 | 09:55 PM
savage21's Avatar
i think i burnt my belt up this weekend to i was pulling a big bear out and now the cover has a smaall burn place on it havn't opened up and looked at belt yet,
Old Feb 14, 2004 | 12:48 AM
Chadillac's Avatar
Sorry its kind of off topic but you have the same quad as me. Have you had trouble with the chain drive on the fornt whells of your 95 scrambler.
Grinding Disengageing under pressure?
Old Feb 15, 2004 | 06:27 PM
savage21's Avatar
You need to adjust the chains adjust all remember you have 3 different chains
Old Mar 29, 2004 | 01:11 AM
Redbullssg's Avatar
Yea, I did that going through mud very slow. Just can't take the heat...
Old Mar 30, 2004 | 04:23 PM
quadblazer400's Avatar
they say the worst thing you can do with an auto matic is get too crazy trying to pull some one out, you'll fry your belt very fast before you realize it, get off and push , its cheaper!
exmotocrosser
Sep 13, 2019 06:12 AM
wendal
Oct 31, 2017 03:31 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
