clicking in rear on sp700.........HELP
Old Sep 7, 2003 | 06:12 PM
BONEshock's Avatar
Default clicking in rear on sp700.........HELP
barrings or CV joint
Old Sep 7, 2003 | 07:19 PM
V8s10's Avatar
Is it loose where the axle goes into the cv joint cup or where the cv joint goes into the gearcase?
Old Sep 7, 2003 | 10:50 PM
bear600's Avatar
mine was doing the same thing 2004 sp600 you have a bade cv joint.
Old Sep 7, 2003 | 11:07 PM
curlytop's Avatar
What would I have to take off to get to that cv joint.
Old Sep 8, 2003 | 06:35 PM
  #15
curlytop's Avatar
come on now, what do you have to take off to get to the cv joint by the gear case.
Old Sep 11, 2003 | 11:16 PM
  #16
upnort's Avatar
Never had my rear one off only front. heard rear is bit more involved cost 80 for me just to have boot replaced. (parts and labor). Partsland.com has some exploded views of that area helped me with front one. Know you have to take the hub nut off to remove it also have to undo the lower A-arm outer bolts. Fraid that is bout as far as I can go. If the joint is bad may need to replace entire shaft, may be easier and more reliable in the long run.
Old Sep 13, 2003 | 12:51 AM
  #17
solomonsatvs's Avatar
I'm working on the same problem tonight. Jack the rear end up. If one of your back wheels has play in it it could be the bearing but I doubt it. The bearing cost around $65.00. Mine was the cv joint and thats not a repair you want to tackle, replacing a piece of the rear cv drive shaft. I was fortunate and found an entire cv axle assembly on ebay for $90.00. I'm just trying to find out how to pull my old axle out and be done with it. The boots are held on by metal clips that take a special polaris tool to take off and put on. Go to ronnies.com and price a new axle and it's about $250.00. Wish I had better news.
Solomon's
fordfaithful21
Dec 7, 2015 05:52 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
black_thunder
Sep 7, 2015 01:24 AM
Pahuntman
Sep 5, 2015 11:07 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
