2Cycle Oil
Old Oct 3, 2003 | 12:33 PM
Stolle's Avatar
Default 2Cycle Oil
I have a 1996 Express 300. Since 96 I have been running the regular 2 cycle engine oil in it. I want to switch to a synthetic oil. I reviewed some post from the past about about using Bombadier Rotax, Amsoil, and Pennzoil synthetics because the are less expensive than the Polaris brand oil. Any specifications I need to look for? Any advice would be appreciated.
Thanks in advance
Matt
Old Oct 3, 2003 | 02:30 PM
95sport400's Avatar
Default 2Cycle Oil
Regular Amsoil 2-stroke injector oil will work perfect for you.
Old Oct 3, 2003 | 03:09 PM
TKBOB2000's Avatar
Default 2Cycle Oil
Well the only advice I have is to drain the oil injection system of your old oil befor adding your new oil. I have heard many stories of people who do not drain their systems and for some reason their motor ends up in tiny little peices. So to be safe I would drain it and add the new stuff.
Hope that helps
Old Oct 3, 2003 | 04:45 PM
Stolle's Avatar
Default 2Cycle Oil
I picked up a gallon of bombadier rotax mineral oil at Wal-Mart. I drained the oil resevoir last night. Do in need to flush the remaining oil out? Its been draining all night and today.
Old Oct 3, 2003 | 10:26 PM
95sport400's Avatar
Default 2Cycle Oil
No you don't need to flush it but you do need to properly bleed/prime the injector pump. If you don't have a service manual, do a search on here.
Shainasmash
May 8, 2017 06:38 PM
qingqi50
Jun 26, 2015 01:58 AM
Xplorer1
Nov 8, 2014 04:54 PM
bruiser0266
Sep 23, 2012 09:48 AM
Sonicpilz
Dec 17, 2006 11:17 PM
