'94 400L kills when put in reverse w/o override
Old Oct 14, 2003 | 04:37 PM
morehp's Avatar
Default '94 400L kills when put in reverse w/o override
My '94 400L engine kills when I put it in reverse if the override button is not pushed. If I push the override button, it will stay running. What should I be looking at to troubleshoot this wierd electrical problem. Getting really annoying...
Old Oct 14, 2003 | 07:24 PM
ftwflh's Avatar
This is a common thing with the older Polaris.The easiest and cheapest thing to do is find the limiter box and follow the wires to the wire block and unplug the BLACK wire.This will elleminate the reverse override but you will still have to hold the button in for the 4x4 to work.Or you can replace the limiter box and I think it is around $50.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
