top speed varies?...sp700
Old Oct 23, 2003 | 05:11 PM
yoopermike's Avatar
Default top speed varies?...sp700
hey lovemud, i may have found the problem with mine. the carb vent tube that's under the seat was blocked off, i repostioned it. i'll be testing it this weekend at camp. my buddies on the other hand, seems to have a different prob. he said sometimes the tach was reading 6500rpm's ,or something like that, while it was running the slower speeds. but on the faster speeds it was running about 5800. i was thinking maybe it wasn't upshifting all the way. he's gonna be tinkering tonight with the clutching.
Old Oct 23, 2003 | 07:27 PM
Polaridoo's Avatar
If you are getting close to hitting top RPM, then its in your clutch, otherwise look towards the engine (carb, airfilter, carb intake boot, spark plugs, ignition, etc)
Old Oct 23, 2003 | 09:30 PM
yoopermike's Avatar
i remember reading something about the carb boot , what was that about, cracked or loose or something?
Old Oct 23, 2003 | 10:51 PM
Bill35's Avatar
Not in the 03s the early 02s had bad carb boots I know I had to replace one.
Old Oct 24, 2003 | 10:21 AM
  #15
lovemud's Avatar
I seem to recall a post about there being (or should be) a filter on the end of that vent tube to prevent stuff from finding its way into the carb. If that tube is blocked the machine won't run right. ( I keep forgetting to check my own machine to see if it has one or not).
The other machine sounds like a good candidate for a loose plastic stop nut on the spider as 700 at Washington mentioned.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
